Вы здесь » Ремонт ноутбука своими руками. » HP, Sony » Hp compaq 6830s enabling-disabling +V5A and +V3A
Сообщений 1 страница 23 из 23
Hello,
Got for repair a dead Hp compaq 6830s. +V3AL was shorted. Traced line, replaced KBC1091 and short was gone.
Now, VREG3 and VREG5 are ok, but +V5A and +V3A are absent. EN1 and EN2 are 0V.
Got a little confused and wish to be clarified on the following points :
*1-how +V5A and +V3A are unabled and disabled through Q1036-Q1037 and Q1038 ?
see attached portion of scheme.
*2-R1242 is marked "0_5%_OPEN" on scheme. On the mobo, there are 2 soldering pads but no resistance found. Should R1242 remain open or need to solder a 0_5 R to help issuing EN1 and EN2 signals ?
http://sh.uploads.ru/t/qvizd.jpg
Отредактировано mohkamtun (15.04.2015 14:57:37)
:confused:
Drawn kind of nonsense  :suspicious:
Judging by the diagram, +V5AL through R1242 goes on EN2 and EN1.
It is unclear what function does Q1038
Channel 1 and Channel 2 SMPS enable pins. Connect to 5 V to turn on with internal 3-ms soft-start.
If there are no +V5AL , this may be due to the fact that open Q1038 or Q1036 and Q1037
If you remove R1242 , what voltage will be included EN1 and EN2 ?
:dontknow:
It works like this :
+V5AL goes to the gate of the Q1038
Q1038 open
+V5AL through the open Q1038 go to the ground
On EN1 and EN2 goes nothing.
Receives signals VCC1_POR#_3 and KBC_PW_ON
Q1036 and Q1037 -   open
+V5AL through Q1036 and Q1037 goes to the ground.
Q1038 - closes
+V5AL through R1242 arrives at En1 and En2
R1242 is not on the chart, it is marked on the "open" is a common bridge.
+ V5AL through R1243 opens Q1038 and extinguishes all the 5 volt line, but as soon as the Q1036 comes from the earth, the Q1038 is closed and 5 volts through R1242 goes to ENABLE1 and 2
It works like this:
+ V5AL goes to the gate of the Q1038
Q1038 Open
+ V5AL through the Open Q1038 go to the Ground
EN1 and EN2 On goes nothing.
Receives signals VCC1_POR # _3 and KBC_PW_ON
Q1036 and Q1037 - Open
+ V5AL through Q1036 Q1037 and goes to the Ground .
Q1038 - closes
+ V5AL through r1242 arrives at En1 and eN2
It's now clearer, but to be most clear :question:
1*-Are both VCC1_POR # _3 and KBC_PW_ON signals needed for issuing En1 and
En2 ?
2*- VCC1_POR # _3 is issued automatically through LM393 when +V3AL, +V5AL are present, but what makes KBC_PW_ON issued from EC, is it ADP_PRES ?
3*- So R1242 is necessary for issuing En1 and En2 ?
Then :
R1242 is not on the chart, it is marked on the "Open" is A common Bridge.
R1242 is marked on the scheme 0_5%_OPEN, what exactly _OPEN marking means, does it mean small resistive bridge?
Thank you for putting light on these points ?
En2 ?
yes
Don't worry your head.
This is just one of the signals triggering 51120
yes
OPEN this means that the element is not installed.
it is not needed, because it 0 Ohm.
Отредактировано Сеган (17.04.2015 01:29:21)
+ V5AL through R1243 opens Q1038 and extinguishes all the 5 volt line, but as soon as the Q1036 comes from the earth, the Q1038 is closed and 5 volts through R1242 goes to ENABLE1 and 2[
Now again I'm getting confused, when Q1038 is closed 5 volts gets through R1242  ohm, if R1242 isn't installed and not needed OPEN, how 5volts En1 and En2 will be issued ? particularly given that on mobo there is no direct track from +V5AL line to drain to be able to do without the O Ohm R1242! :confused:
Сеган wanted to say that R1242 is a resistor with a resistance of 0 ohms .
And instead of this resistor it is possible to put the jumper.
But in any case, this circuit must be a closed circuit . Because this resistor is fed a positive voltage to turn on EN1 and EN2
:cool:
It's clear now. My thanks to you and to Segan.
Feed back :
Ok added missing R1242 to circuit, got EN1 and EN2=2V, so the +V5AL supply  to R1242 collapses in 2V. Suspected TPS51120 and desoldered it.
Before it's replacement, I connected adapter in order to identify the malfunction of Q1031, which I previously shunted.
At this stage, a tragic problem happened, a smoke came from U1007 Lan Controller, also, +V3_LAN and +V3A rail were shorted to gnd ? a phenomenon that I couldn't undertand as no voltages should exist, when TP51120 is removed, except the +VBATP, do you agree ?
Also found resistance of +V5A to gnd very small : 29 Ohms ?
Removed smoked U1007, and traced thoroughly +V3A line : found and removed shorted Q27,  U1021 and U1017 but +V3A SHORT is not yet gone ?
1*-So, what probably happened to kill simultaneously Lan Controller, Q27, U1021 and U1017 though TPS51120 was removed ? :confused:
:question:
2*- What else to check to solve short issue on +V3A rail ? Already supplied rail with  +3VDC power supply, didn't find any component which heats !
3*- How to solve +V5A line "29 Ohms resistance" to gnd ?
Unfortunately lot of steps back in this repair, as a result of this tragic problem! :smoke:
Thank you for giving good steps to solve these issues .
Отредактировано mohkamtun (21.04.2015 01:58:32)
You deleted TPS51120 and turned on the laptop ?
Yes, I turned on laptop with TPS51120 removed for the reason mentioned and that caused the tragic problem described on my previous post with no clear reason.?
To turn on the laptop without the PWM controller-never !
without PWM TPS51120 Q27 and Q31 launched 19 Volts on the motherboard. (mosfets opened)
19 Volt caugt on +V5A  and +V3A  - clear now?
almost everything that touches these lines - dead  :insane:
Now, the repair will be very difficul :tired: t
Отредактировано Сеган (21.04.2015 22:22:34)
Now, the repair will be very difficul  t
Отредактировано Сеган (Вчера 20:22:34)
I connected adapter thinking that, as TPS51120 is removed, Gates of Q27, Q31 and Q30 are not driven, so the 3 mosfets will be closed and no voltages will be outputted on +V5A and +V3A lines, and that's why I was surprised by the big damage!
:question:
1*- If I have good understood, you confirm that, though gates are open (not driven by any signal), 19V supply should be present on outputting coils ?
2*- If yes, then shall I conclude that I must never connect adapter when any of the  system regulator IC (those supplied with +VBATR) is removed ?
Thank you for following up the 2 above questions.
Yes. They sometimes remain open briefly, it is enough to have passed 19 V ...
Yes. Never. if you are using the same principle shemes.
You can turn on after removal of the MOSFETs Q27 and Q31
do you speak Russian?
Отредактировано Сеган (22.04.2015 22:51:37)
Clear (+V3A/+V5A) Regulator Ic is required or have to remove upper mosfets, before turning on, but :
Wish to know precisely if any damage is expected, when powered on with PWM TPS51120 soldered, but VCCP or +VDD_CORE OR +VCC_CORE regulator Ic is removed?
Unfortunately, I don't speak Russian, but besides english I speak french, italian, german, arabic, a little spanish, some sentences in finish language and some words in Russian, as I studied Russian language for some months but many years ago.
Отредактировано mohkamtun (22.04.2015 23:57:31)
It is strange that you do not seek help for English-speaking forums. Why?
I posted in different english speaking forums, but most of replies I got were from beginners.  As I already studied laptop repair chip level and got experience in the field for some years, I need professional help to improve my knowledge and that's what I'm thinking to get in your forum.
Hello,
I asked in my post 17, whether any damage could happen, when powered on with PWM TPS51120 soldered, but VCCP or +VDD_CORE or +VCC_CORE regulator Ic is removed?.
Thank you
Hello,
Thank you
GATE of the transistors to hang in the air should not.
Отредактировано Сеган (24.04.2015 01:24:59)
Edited Segan (Yesterday 23:24:59)
Thank you for your advice.
Hello,
Well, as I found many components shorted, think it's not worthwhile to continue  repairing this mobo. Took another clean but dead 6830s mobo for repair, +3.3V and +5V are absent.
Will dig and give feed back soon.
