toshıba l50 vgsg mb rev 2.1 BoardViewer
Страница: 1
Поделиться405.09.2019 14:20:03
Short to Ground via 19V Resistor
+ac_bat_sys
How do you follow this earth short circuit
Отредактировано asliyucegsm (05.09.2019 15:08:08)
Поделиться505.09.2019 14:26:42
Remove the resistor, check which side is short circuit.
In the direction of a short circuit from the laboratory power supply 1 volt a couple of amps and find the elements subject to heat.
Страница: 1
