my friend
asus x75vb rev.3.0
this is my motherboard how can i disable the front card ram
link:https://disk.yandex.com.tr/d/8VHn4xCa5T_oLQ
note:I changed the place of the resistors from the schematic, the ram is still in the circuit, do I need to change the bios edit and other resistors?
can you edit my bios
thanks
Отредактировано asliyucegsm (24.03.2023 12:15:05)
