Acer Aspire 3020/3610/5020/5040, Travelmate 2410/4400: 50.4C501.002, 50.4C503.002, 50.4C509.001, 50.4C515.001, 50.4C516.001 - Wistron Bolsena/Bolsena-E/Morar
Acer Aspire 3050/3680/5050/5570/5580, Travelmate 2480: DD0ZR1LC008 - Quanta ZR1/ZR3
Acer Aspire 3100/3650/3690/5100/5101/5102/5103/5110/5610/5630/5650/5680/9120, Travelmate 2450/2490/4200/4260/5510: DC020007000, DC020007N00, DC020007O00, 50.ABHV5.008 - Compal HBL50/HBL51/HCL51/HCW50/HCW51
Acer Aspire 4220/4320/4520/4720: DD0ZO1LC000, DD0ZO1LC100 - Quanta ZO1/ZO3
Acer Aspire 4251/4551/4741/4750; eMachines D440/D640/E440: 50.4GW01.013, 50.4GW01.022 - Wistron JE40/HM42
Acer Aspire 5230/5530, Travelmate 4235/4530: DC02000JL00 - Compal JALB0
Acer Aspire 5232/5241/5332/5516/5517/5532/5541G/5732; eMachines E430/E525/E625/E627/E630/E725/G430/G627: DC02000SS00, DC020000Y00 - Compal KAWF0/KAWG0/KAWH0/NAWF2/NCWG0/NCWH0/NDWG2/NDWH1
Acer Aspire 5250/5251/5252/5253/5333/5336/5551/5552/5733/5736/5741/5742; eMachines E442/E443/E640; Gateway NV50/NV51/NV53/NV59; Packard Bell EasyNote F4211/TM81/TM82/TM83/TM89/TM94/TM98: DC020010L10, DC020010N00, 50.WJ802.008 - Compal NEW70/NEW90/NEW95/PEW71/PEW96
Acer Aspire 5310/5315/5520/5710/5715Z/5720; eMachines E510: DC02000DS00, DC02000G800 - Compal ICL50/ICL51/ICW50/JDW50/JDY70
Acer Aspire 5338/5536/5542/5738: 50.4CG13.021 (5338 CCFL), 50.4CG13.032 (5536), 50.4CG14.002 (5738Z), 50.4CG14.021 (без камеры), 50.4CG14.022 (5738G, 5542G), 50.4CG14.031 (LED), 50.4CG14.032 - Wistron JV50
Acer Aspire 5350/5750/5750G/5755/5755G; Gateway NV55/NV57: DC020017K10, DC02001DB10 - Compal P5WS0
Acer Aspire 5600/5620/5670, Travelmate 4210/4220/4270/4670: DD0ZB1LC107 - Quanta ZB1/ZB2
Acer Aspire 5942/5942G: 50.PMV02.001 - Compal NCQD0
Acer Aspire 6530/6930: DD0ZK2LC200, GLEDD0ZK2LC200, 50.AUQ07.001 - Quanta ZK2/ZK3
Acer Aspire 7000/7110/9300/9303/9304/9400/9410: 50.4G501.002, 50.4G903.005, 50.4G903.006, 50.4G904.002, 50.4Q909.001 - Wistron MyAll/MyAll2/MyAllM
Acer Aspire One A110/A150/ZG3/ZG5: DD0ZG5TH100, DD0ZG5TH101, 50.S0207.003 - Quanta ZG5
Acer Aspire One D255/D260; eMachines 355; Packard Bell Dot S/Dot U/Dot SE/Dot SE2/Dot S-E3: DC020016810, DC020012Y50, 50.SCH02.006 - Compal NAV70/PAV70/PAV80
Acer Aspire E1-521/E1-531/E1-571/V3-571; Gateway NE56/NV56; Packard Bell EasyNote TV11: DC02001F010, DC02001FO10 - Compal Q5WV0/Q5WVH
Acer Extensa 5235/5635; eMachines E528: DD0ZR6LC100, DD0ZRGLC010, DD0ZRGLC020 - Quanta ZR6/ZRG
Asus A6F/A6G/A6J/A6K/A6L/A6M/A6NE/A6R/A6T/A6U/A6V, F6A/F6E/F6V: 08G26AV8111M, 08G26AV8111N, 14G2206FS20M, 08-26AV8111N
Asus A8E/A8J/A8M/A8S, X80L/X80LE, Z99F/Z99H/Z99HE/Z99J/Z99L/Z99M: 08G28AJ8001M, 08G28AJ8001N, 08G28AP8010M, 14G2208AJ10R
Asus A9T, F5C/F5GL/F5M/F5N/F5R/F5RL/F5SL/F5SR/F5V/F5VL/F5Z, PRO50N, PRO55, X50C/X50GL/X50M/X50N/X50Q/X50R/X50SL/X50V/X50VL/X50Z, X59G/X59GL/X59S/X59SL/X59SR: 08G25FR8121M, 08G25FR8121U, 14G100313802
Asus A53E/A53S, K53E/K53S/K53SC/K53SC/K53SD/K53SJ/K53SK/K53SM/K53SV, X53E/X53S/X53SJ/X53SV: 04G620008610, 14G221036000, 14G221036001, 14G221036002, 14G221036004
Asus A53T/A53U, K53B/K53BE/K53BR/K53BY/K53T/K53U/K53Z, X53B/X53U/X53Z: DC02001AV10, DC02001AV20 - Compal PBL60/QBL60
Asus F3F/F3H/F3J/F3K/F3L/F3M/F3Q/F3S/F3T/F3U, M51K/M51KR/M51S/M51SE/M51SR/M51T/M51TA/M51TR/M51V/M51VA/M51VR, PRO31E/PRO31F/PRO31H/PRO31J/PRO31JA/PRO31JC/PRO31JF/PRO31JP/PRO31JR/PRO31JV/PRO31K/PRO31L/PRO31M/PRO31P/PRO31Q/PRO31S/PRO31SA/PRO31SC/PRO31SG/PRO31SV/PRO31T/PRO31U, PRO57K/PRO57S/PRO57SE/PRO57T/PRO57TR, PRO59L/PRO59LE, Z53E/Z53F/Z53H/Z53J/Z53JA/Z53JC/Z53JM/Z53JP/Z53JR/Z53JV/Z53L/Z53M/Z53P/Z53S/Z53SC/Z53T/Z53TC/Z53U: 08G23FC8010M, 08G23FC8010U, 14G2203FA10R, 14G2203FA12U, 1422-000T000
Asus F52A/F52Q, F82A/F82Q, K40AB/K40AD/K40AF/K40C/K40ID/K40IJ/K40IL/K40IN/K40IP, K50AB/K50AD/K50AF/K50C/K50ID/K50IE/K50IJ/K50IN/K50IO/K50IP, K51AB/K51AC/K51AE/K51IO, K60IJ/K60IL/K60IN, K70AB/K70AC/K70AD/K70AE/K70AF/K70IC/K70ID/K70IJ/K70IL/K70IO, P50I/P50IJ, PRO5 Series, X52N, X5DAB/X5DAD/X5DAF/X5DC/X5DID/X5DIE/X5DIJ/X5DIL/X5DIN/X5DIP, X8AAB/X8AAD/X8AAF/X8AC/X8AID/X8AIE/X8AIJ/X8AIL/X8AIN/X8AIP: 14G2204KI11M (K40IJ), 1422-00FY0AS, 1422-00G1000, 1422-00G10A9, 1422-00G10AS (K50C), 1422-00G90AS (K50C), 1422-00GA0AS, 1422-00HB0AS, 1422-00JS0AS
Asus F80C/F80CR/F80L/F80Q/F80S: 14G2218AS10M
Asus L50V/L50VC/L50VM/L50VN, M50S/M50SA/M50SR/M50SV/M50V/M50VC/M50VM/M50VN, PRO58S/PRO58SA/PRO58SR/PRO58V/PRO58VC/PRO58VM/PRO58VN, X55S/X55SR, X57S/X57SV/X57V/X57VN: 14G2221NV10M, 14G2231NV20D, 1422-002M000
Asus Eee PC 1001HA/1001HAG/1001HGO/1001P/1001PQ/1001PX/1001PXD, 1005HA/1005HAB/1005HAG/1005P/1005PE/1005PR/1005PX/1005PXD, 1011CX, 1015P/1015PD/1015PE/1015PEB/1015PED/1015PEM, 1016P/1016PT: 1422-00MK000, 1422-00ML000, 1422-00TJ000 (BLK005X), 1422-00P3000A7, 14G2235HA10G, 14G2235HA10N, 14G2235HA10Q, 14G2235HA10U, 14G2235HA10V, 10G16G003339
Asus Eee PC 1215B/1215N/1215P/1215T: 1422-00SF000, 1422-00SL000
BenQ Joybook R55V; Gigabyte W551N; Philips Freevents X58/X72; Roverbook Voyager V550: FOXDD0TW3LC000
Compaq Evo N600/N610C/N620C: 6017A0020001
Compaq 510/511/515/516/610/615: 536424-001 (610), 538419-001, 538463-001 (610), 572530-001 (615), 6017B0200702 (615), 6017B0240301
Compaq Presario CQ50; HP G50: 50.4H506.002, 50.4H507.001, 50.4H508.001, 486561-001, 486583-001 - Wistron Astrosphere/Warrior
Compaq Presario CQ61; HP G61: DD0OP6LC001, DD00P6LC801, DD0OP6LC801, DD00P6LC804, DD0OP6LC804, 577068-001 - Quanta OP6/OP7/OP8
Compaq Presario F500/F700; HP Pavilion dv6000/dv6500/dv6700: DDAT8ALC004, DDAT8ALC1013A, FOXDDAT8BLC0091A, GLEDDAT8ALC1013A, 431394-001, 432298-001 - Quanta AT8
Comstar Colibri: DD0ON1LC000 - Quanta ON1
Dell Inspiron 1100/1150/2600/2650/5100/5150/5160: DC025036400, DC025041100, DC025062700 - Compal BDW00
Dell Inspiron 1500/1501/1520/1521/1720, Vostro 1000/1400/1500: DD0FM5LC200, DD0FM2LC507, 0PM853 - Quanta FM5/FX2/GM2
Dell Inspiron 1525/1526: 50.4CR03.012, 50.4W001.001, 50.4W001.101, 50.4W001.301 - Wistron Spears
Fujitsu-Siemens Amilo A1650/A1650G: 50.4B304.001, 50.4B305.001 - Wistron W37
Fujitsu-Siemens Amilo Pro V2030: 22-11553-80 - FIC LM7R
Fujitsu-Siemens Esprimo Mobile V5515/V5535/V5555: 6017B0140701 - Inventec Z17M
HP 510/520/530: DC02000D700, DC02000DY00, 438537-001, 440708-001, 448334-001 - Compal IAT00/IAT10/IAT50/IAT60
HP 550; HP Compaq 6720s: 6017B0128401, 456802-001, 456802-001, 456801-001 - Inventec DDD
HP 630: 350407B00-H0B-G, 646842-001, 646844-001 - Foxconn Chicago
HP Compaq nc6110/nc6120/nc6320/nx6110/nx6120/nx6310/nx6315/nx6320/nx6325: 6017B0007701, 6017B0085501, 330855-252, 378209-001, 396000-251, 413677-001, 413678-001, 416944-001, 430867-001, 430868-001 - Inventec Davos/Taos
HP Compaq nc6220/nc6230/nc8230/nx8220: 6017A0043401, 6017A0043402, 325281-141, 382682-001, 382684-001, 396002-541 - Inventec Vail 1.0
HP Pavilion dv5-1000/dv5-1100 CCFL: DD0QT6LC800, FOXDDC7003CSD314, 484367-001, 484371-001, 493020-001 - Quanta QT6
HP Pavilion dv6-1000/dv6-2000 LED: DD0UP8LC000, DD0UP8LC002, DD0UP8LC0004, DD0UP8LC006, DD0UP8LC101, DD0UT3LC301, 538312-001, 570095-001, 593004-001 - Quanta UT3/UT5/UP8
HP Pavilion dv7-2000/dv7-3000: DD0UT5LC000, DD0UT5LC003, DD0UT5LC004, DD0UT5LC100, DDC00LC3C040, 509407-001, 516307-001, 519259-001 - Quanta UP6/UT1A/UT3D/UT5
HP Probook 4510s/4515s/4710s: 6017B0197901, 6017B0241101, 535853-001, 536787-001, 536793-001, 598702-001 - Inventec Invicta/Zenith
Lenovo IdeaPad B560/V560: 50.4JW09.001, 50.4JW09.011 - Wistron LA56
Lenovo IdeaPad G550: DC02000RH00, DC02000RH10 - Compal KIWA7/KIWA8
Lenovo IdeaPad L510/Y510/Y520/Y530: 14G2200SD10, 1422-004Q0L, 14G140170410LV - Asus Speedy
Lenovo ThinkPad R61/R500: 93P4380, 93P4447, 93P4449, 93P4450, 93P4451, 93P4551
LG LM50/LS55: 6851B76028A, 6851BZ9207B, 6851BZ9207C - Inventec McKinley
MSI Wind U90/U90X/U100/U100X/U110/U115/U120/U120H/U130/U135/U135DX: K19-3026006-V03, K19-3026009-H58, K19-3026012-V03, K19-3030016-H39, K19-3030017-H39, K19-3030018-H58, K19-3030019-H58, K19-3030024-H58, K19-3030028-H58
MSI Wind U160/U160DX/U160DXH/U160MX: K19-3019002-H58 - MS-N0511
Packard Bell EasyNote TJ61/TJ62/TJ63/TJ64/TJ65/TJ66/TJ67/TJ68; Gateway NV52/NV53/NV54/NV55/NV56/NV58: 50.4BU01.002, 50.4BU01.012 (TJ65), 50.WBM01.003 - Wistron SJV50
Roverbook Explorer B571: ? - Uniwill 757iA
Samsung E352/R523/R525/R528/R530/R538/R540/R580/RV510: BA39-00929A (rev. 2.0), BA39-00932A (rev. 4.0) (R530), BA39-00951A (rev. 1.0) - Samsung Bremen
Samsung P27/P28/P29: BA39-00420A, BA39-00457A - Samsung Oscar
Samsung R40: BA39-00596A, BA39-00611A, BA39-00612A - Samsung Firenze-2
Samsung R408/R410/R455/R460: BA39-00676A, BA39-00680A, BA39-00777A - Samsung XI'AN TY3C
Samsung R610: BA39-00728A, BA39-00732A - Samsung Istanbul
Samsung X06: ? - Samsung Aquila
Toshiba Satellite A10/A15: 30513NJ, 31212DG01
Toshiba Satellite A50/A55, Tecra A2: GDM900000427 - Toshiba FLKSY2
Toshiba Satellite A200/A210: DC02000F900 - Compal ISKAA/ISKAE
Toshiba Satellite A205/A215: 6017B0103601 - Inventec Milwaukee
Toshiba Satellite A300/A300D/A305/A305D: 6017B0147801, DD0BL5LC000, GLEDD0BL5LC000 - Inventec Potomac PT10G/PT10SG, Quanta BL5S
Toshiba Satellite A500/A500D/A505/A505D: 6017B0201901, 6017B0202001 (LED), DC02000UD00 (CCFL), DC02000UG00 (LED) - Compal KSKAA/KSKAE/KSWAE/NSKAA, Inventec CS10
Toshiba Satellite A660/A660D/A665/A665D: DC020012110 - Compal NWQAA
Toshiba Satellite C650/C650D/C655/C655D/L650/L650D/L655/L655D: DD0BL6LC000, DD0BL6LC010, DD0BL6LC030, 6017B0265501 - Inventec Berlin
Toshiba Satellite C660/C660D/C665/C665D/P750/P750D/P755/P755D: DC020011Z10, DC02001BG10 (C660-1V9) - Compal PWWAA/PWWHA
Toshiba Satellite L40/L45: 08G2200TA10M, 14G2202TS10MTB - Asus Teresa
Toshiba Satellite L300/L300D/L305/L305D: 6017B0146701 - Inventec Phoenix/Sacramento
Toshiba Satellite L350/L350D/L355/L355D: 6017B0147501 - Inventec Robson
Toshiba Satellite L455/L455D: DC020010100 - Compal NBWAA/NBWAE
Toshiba Satellite L500/L500D/L505/L505D: 6017B0198301, DC020001U00, DC02000S800, DC02000UC10 - Compal KSWAA/KSWAE
Toshiba Satellite L550/L550D/L555/L555D: DC02000S910 - Compal NSWAA/NSWAE
Toshiba Satellite L630/L630D/L635/L635D/L735/L735D: 6017B0268701 - Inventec Bremen BM10G
Toshiba Satellite L670/L670D/L675/L675D: DC020011H10 - Compal NALAA
Toshiba Satellite L750/L750D/L755/L755D: DD0BLBLC000, DD0BLBLC040 - Quanta BLBL
Toshiba Satellite P100/P105: DD0BD1LC009 - Quanta BD1
Toshiba Satellite P200/P205/X200/X205: DC020000DM00 - Compal ISRAA
Toshiba Satellite P300/P300D/P305/P305D: DD0BD3LC000 - Quanta BD3G
Toshiba Satellite P500/P500D/P505/P505D: DD0TZ1LC000 - Quanta TZ1C/TZ2T
Также имеются в наличии инверторы
Цены от 500 до 1500 руб.
+7 (926) 595 99 85, аська 271 565 133
Москва и область. Можно почтой
Отредактировано D@nilYcH (28.03.2013 01:15:47)
Покупаю! свяжусь! по Skype отправил запросс...
