Hello, here I'm back.
Got a dead Toshiba NB200 for repair. Platform : KAVAA LA-5121P Rev : 2.0
Found both lines +3VALW and +5VALW shorted.
Desoldered PJ1 and PJ3 to isolate short issue.
Replaced bad RT8206B (SN0806081) with a good working TPS51427 and removed shorted E/C KB926QF, +3VALW line short is gone (PL4 to gnd=305R).
Replaced shorted PQ21 and PC60, +5VALW load line TO GND =16R.???
Traced this line and found VCC usb shorted to gnd : replaced bad C455, and removed U18 and U21 (USB power supply fets) found partially short, now +5VALW load line to gnd measures : 90R.???
Soldered back PJ1 and PJ3 and connected power adapter, +5VALW and +3VALW are always absent, and PQ21 AND PC60 ARE SHORTED AGAIN.
Wish to get confirmed :
*1-I guess the 90R Resitance to gnd found on +5VALW line is not normal, do you agree ?
*2-Could +5VALW and +3VALW be issued for this platform, if mobo is powered with EC desoldered?
*3-What could cause the PQ21 and PC60 to short again ?
Many thanks for your help.
Отредактировано mohkamtun (11.04.2015 20:35:51)
