Hi Members !
I need a working dump file for hp pavillon dv7-1240ek.
Platform : JAKOO LA-4083P REV 1.0
Downloaded dump "sp51315.exe" from hp site, didn't work.
Thank you
Вы здесь » Ремонт ноутбука своими руками. » HP, Sony » working dump bios file for dv7-1240ek
Hi Members !
Thank you
Inside sp51315.exe - there are three files :
30F4F2D0.FD
30F4F2D1.FD
30F3F2D.FD
Comparing to the native dump files from 51315 ?
Served overwrite all files ?
Inside sp51315.exe - there are Three Files:
30F4F2D0.FD
30F4F2D1.FD
30F3F2D.FDComparing to the native dump files from 51315?
Served Overwrite All Files?
I used different dumping files, but always no display on lcd and monitor.
Add, motherboard is discrete type.
Should it not be rather a graphic issue ?
Maybe it is
Is there some kind of indication for Caps Lock & Num ?
And the platform is definitely LA-4083P ?
30F3F2D.FD - is UMA
Two options for discrete modifications :
30F4F2D0.FD - is discrete type
30F4F2D1.FD- is discrete type
Phoenixtool ругается что это не Phoenix, AwardTool тоже ... кто биос?
Да они ж там вроде в открытом виде. Ты че хочешь с ними сделать ?
Точняк! Просто смутило, что биос метровый всего.
Maybe it is
Is there some kind of indication for Caps Lock & Num?
And the platform is Definitely LA-4083P?30F3F2D.FD - is UMA
Two options for discrete modifications:
Hi freeqwer!
Platform is actually LA-4083P-discrete.
Made a mistake, by using UMA dumping file i.e 30F3F2D.FD
Got then 4 led blinks which meaned graphic absent
Display fail was solved when I dumped with 30F4F2D1.FD
Thank you really for drawing my attention to the discrete file.
إذا ماذا ؟
عملت على 30F4F2D1.FD ?
إذا ماذا?
عملت على 30F4F2D1.FD?
hi freeqwer,
I noticed with pleasure the words in arabic.
By the way, are you learning arabic ?
No .
Just translated into Arabic .
Maybe you prefer ?
No.
Just translated into Arabic. Maybe you prefer?
Thank you any way for giving a trial.
Also no problem, if you write in French, German, Italian, I can understand, but unfortunately not yet Russian.
I wish to learn at least Russian technical words related to lap and motherboard repair job.
May I post a topic on desktop motherboard repair, or is this forum only for laptop repair ?
Also, I need diagram for SMSC sch5514 I/O controller for Dell optiplex 745 mobo, I got for repair.
Do you have any download link to the controller and eventually to the motherboard schematic ?
Yes , it is possible in this section : LINK
P.S. There is a translator site :
1*-Link needed is rather for SMSC sch5514 I / O controller datasheet.
I got datasheet of SMSC sch5504 with same number of pins but wonder whether pinout is same!!
2*-P.S write url of the translator site, image link didn't help.
