freeqwer написал(а):1100011 - corresponds to the value 0.2625 V
Y're right it's 0.2625V, I got confused. (Already, 1.54V doesn't exist in VID table max +1.5V)
freeqwer написал(а):I'm not sure you can check this PWM without a processor.
You need to carefully read the Datasheet.
It should be made conditions :
- VCCDRE_EN
- H_VID [0: 6]
- IMVP_CKEN #
- PM_DPRSLPVR
Yes, it seems that processor is needed for checking PWM.
Today, I shorted VID1 and VID2 to gnd and got VCC_core +1.12V (should be +1.0V according to VID table
0101000). +10%volts, I think it's within tolerance, isn't it ?
freeqwer написал(а):Try to set socket processor to perform the disconnection of one phase.
I disconnected both L510 and L513, of course one at a time, and got always VCC_CORE : +0V ?? Processor with only one phase is not working! strange isn't ?
How can we set socket processor to perform disconnection of one phase differently?
Does, Pulling pin SP high (supply of +2V directly to pin 38) help or is there another way to do?
freeqwer написал(а):If there is, it's faster to install a known working PWM.
If not available , then ordered . If anything , it will be useful for the future.
Will try to find out ADP3208 IC on our market and will add it to my pending IC order.
freeqwer написал(а):What is the status signals :
- VCORE_EN
- VR_PWRGD
- IMVP_CKEN #
- TTSEN (TTSNS)
-VCORE_EN : +3.78V
-VR_PWRGD : +3.40V
-IMVP_CKEN# : goes from +0V up to +2.18V (sometimes +1.8V, sometimes +1.4V) and down to +0V-- It goes up to +2.18V and should be so (high) I think when lap is on !! Isn't it ?
-TTSEN : +5.73V
-PM_DPRSLPVR initiates at +0.03V up to +0.12V and down to +0.03V then lap shuts down. It's low and should be so, I think!! Isn't it?
Is any of the above signals incorrect ?
freeqwer написал(а):When the shutdown of the laptop disappears, only the voltage on the CPU ?
What are the voltages on the Board are still working ?
When Lap is ON main existing voltages are :
+5.73V and +3.79V
+2.06V (RAM)
+1.02V instead of +0.9V
VCCP : +1.19V
+1.78V instead of +1.5VS high ??
When lap shuts off : remain only +5.73V and +3.79V.
Many thanks for your support.
